"Matt - as others have suggest
"Matt - as others have suggested, the safts could be installed upside down. There are holes running accross the shafts. Those holes should face downward.....towards the head.
This is a less likely possibility but....if the rebuild involved a new set of heads, it's worth checking the casting numbers to make sure they're not later-model, Magnum, 318 heads. They bolt right up to an older/LA 318 but they oil through hollow pushrods. In other words, in the slim chance that they were later model heads, and you had older-model solid pushrods, there would be no way for oil delivery. Hopefully, it's the aforementioned case of the shafts being upside down."
