"Want to add a fuel sender to
"Want to add a fuel sender to a an aluminum diesel fuel tank. Is it ok just to drill into it with a hole saw when there is diesel fuel in the tank, taking care to vacuum up the cuttings as it is being cut with a shop vac so little falls into the tank? Is this safe or will the battery drill motor spark/s or heat from the friction of the drill be unsafe with the diesel fuel still in the tank?
[email protected]
Thanks, and happy holidays."
[email protected]
