MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
  1. #1
    Join Date
    Oct 2009
    Location
    West Palm Beach, FL, United States
    Posts
    22
    Default "My trim motor went on my 50 h
    "My trim motor went on my 50 hp motor and the motor is down. so to take the motor of i need to trim up my motor, how do i do this? i have a red nob on the the side of the bracket that i thought allowed you to manually trim your motor but it doesnt even move? any help?"
  2. #2
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "there should be a vent/manual
    "there should be a vent/manual release screw, turn it and lift the engine from the bottom"
  3. #3
    Join Date
    Oct 2009
    Location
    Posts
    22
    Default i unscrewed the vent bult but
    i unscrewed the vent bult but the engine will not go up?
  4. #4
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "put it in fwd gear, the rev l
    "put it in fwd gear, the rev lock might be ingauged"
  5. #5
    Join Date
    Oct 2009
    Location
    Posts
    22
    Default "how hard is it going to be fo
    "how hard is it going to be for me to manually tilt it? do i need to jack it up with a jack or should i be able to do this by hand, because i threw it in forward gear and when i pull up it doesnt even budge?"
  6. #6
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "does this help [url=""]http:
  7. #7
    Join Date
    Feb 2009
    Location
    perth, wa, Australia
    Posts
    956
    Default If you have trim and tilt you
    If you have trim and tilt you wont have a reverse lock. If the motor has internal trim and tilt there will be a release screw which you can access through the side of the transom bracket. It turns anti clockwise and undo it about one turn then try to lift the engine.
  8. #8
    Default Re: If you have trim and tilt you
    Was this ever figured out? I have a follow up. I have like an 80 or 81 Johnson Seahorse V4 90hp outboard and the power tilt only now workes in the down direction. This just happened out of nowhere. When I try to raise it I hear the relay clicking, but nothing happens. Each direction has it's own relay, so I swapped relays thinking the contacts might be bad and still only the down direction works, so I know the relays are good. The problem seems to be from the relay box on back to the motor. I cannot lift the motor even when opening the reservoir plug on the pump reservoir. The two lift pistons areattached the the motor housing through holes with locknuts on the otherside which go onto the threaded ends of the lift pistons. I took off those nuts figuring when we lifted the motor manually that the pistons would slide right out of the holes and we could lift the motor. No can do. It's almost as if there's some kind of mechanical thing holding us back because we almost lifted the tail of the boat right off the trailer and the motor did not budge a millimeter when we tried to lift it. Any idea? I can't identify the exact model number because I can't lift the motor to see the model tag on the mounting bracket. All around this really sucks. Any help is appreciated!
  9. #9
    Quote Originally Posted by buixrule View Post
    Had exactly the same problem with my 115 ocean runner. It was stuck down fast and would not budge an inch, no matter how hard I pulled on it.What I discovered by accident I might say is that the motor needs a bit of presure pulling it upwards as you release the manual screw. I put a car jack between my motor leg and my trailer and just wound out a bit of presure and then released the screw, and bingo it popped free and I just lifted the motor manually easy as. Now I just have to figure out why the damn thing will go down and not up.
    Cheers Silverarrow
Similar Threads
  1. Trim motor
    By steveomc in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-31-2008, 06:52 AM
  2. Motor wonbt trim down Even manually
    By big_builder in forum Johnson Evinrude Outboard Archive
    Last Post: 07-15-2008, 05:38 PM
  3. Trim fluid getting into the trim motor
    By aaz in forum Mercury Mariner Outboard Archive
    Last Post: 09-30-2007, 04:32 PM
  4. Can u manually tilt the motor
    By blueyedyankeegirl in forum Volvo Penta Gas Archive
    Last Post: 06-18-2007, 07:28 PM
  5. Trim motor goes up but not down
    By puff214 in forum Mercruiser Sterndrive Archive
    Last Post: 11-01-2006, 08:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
