MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
  1. #1
    Join Date
    Nov 2009
    Location
    cocoa, fl, usa
    Posts
    3
    Default Need help water pump 1989 35 hp merc
    "trying to change waterpump on 1989 35 hp merc 4 bolts removed and shift link disconnected, lower unit will seperate about 1/4" and no more. what next?
    thanks
    clark"
  2. #2
    Join Date
    Feb 2009
    Location
    perth, wa, Australia
    Posts
    956
    Default Have you removed to trim tab a
    Have you removed to trim tab and removed the bolt which holds the rear section of leg to the trunk housing
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,392
    Default Ops! I hope you didn't pr
    Ops! I hope you didn't pry on it too much.
    Jeff
  4. #4
    Join Date
    Nov 2009
    Location
    cocoa, fl, usa
    Posts
    3
    Default "trim tab has been removed , t
    "trim tab has been removed , the nut on the stud under it seems to be missing. i haven't pryed much yet. using the two front nuts with washers on top to push some. seperation stops at 1/4'."
  5. #5
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "sounds all to familiar, how l
    "sounds all to familiar, how long has it been since its been off? some light reading here
    http://www.marineengine.com/discus/m...9/147053.shtml"
  6. #6
    Join Date
    Feb 2009
    Location
    Posts
    956
    Default "I hate to say what e are all
    "I hate to say what e are all thinking but i think the driveshaft is seized in the crank "
  7. #7
    Join Date
    Sep 2003
    Location
    Posts
    15,392
    Default "Agreed. Try this: 1. Hang
    "Agreed. Try this:
    1. Hang the motor upside down by the lower unit, cowling off, with a pad below the powerhead.
    2. Drill a small hole in the driveshaft housing where the driveshaft enters the powerhead--you can epoxy it closed later.
    3. Shoot lots of penetrating oil in there, aiming for the stuck joint, and let it sit--for weeks if necessary--adding a new squirt everytime you pass it by.
    4. For good measure, give te powerhead a good whack with a rubber mallet now and then as well.
    You might get lucky!
    Jeff"
  8. #8
    Join Date
    Feb 2009
    Location
    Posts
    956
    Default I have tried Jeff's method
    I have tried Jeff's method in my shop with success...once it has soaked for a week i would mount the outboard back on the transon and drill a hole through the skeg for a D shackel and then directly underneth on the concret dyna bolt a piece of angle iron with a hole through it and attach a turn buckle...tighten it up and it should pull the leg down.
    The other method which has worked is bolt the outboard back onto the transom and cut a wedge out of wood and knock it inbetween the leg and trunk housing then start the engine...generally the whip in the driveshaft loosens the rusted splines and the leg drops off.
    There is one major problem once the leg comes off the splines in crank and or drive shaft may have rusted away
  9. #9
    Join Date
    Nov 2009
    Location
    cocoa, fl, usa
    Posts
    3
    Default thanks guys. sounds like it w
    thanks guys. sounds like it will work. may be a few weeks before i can get back to work on it. will let you know how it comes out
Similar Threads
  1. 1989 120hp V4 water pump replacement
    By Dfrey1964 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-30-2010, 09:16 AM
  2. 1989 Evinrude 175HP Water Pump
    By Taylin Davis in forum Johnson Evinrude Outboard Archive
    Last Post: 08-08-2008, 06:52 PM
  3. Water pump replacemnt on 1989 225 hp
    By danswinarski in forum Johnson Evinrude Outboard Archive
    Last Post: 02-11-2007, 05:16 AM
  4. 1989 YAMAHA 8 HP WATER PUMP REPLACEMENT
    By JOHN FORGIONE in forum Yamaha Outboard Archive
    Last Post: 03-06-2006, 05:36 PM
  5. 1989 Johnson 120 water pump Joe Help
    By Sammy Evans in forum Johnson Evinrude Outboard Archive
    Last Post: 02-23-2006, 10:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
