Is the 440 a bigger block than a 360 or 318
danny_jones
"I'm replacing the 360 tha
"I'm replacing the 360 that was in my 1968 25' Luhrs with a 440. After installing the V-drive, I've come to find that I am very tight for space between the rudder arm and the pulleys on the block. As it stands, I might have to make some funky exhaust routing to use the original holes in the transom. SO, my question is, is the big block that dimensionally bigger than a smallblock?"
"A few inches in the longitudi
"A few inches in the longitudinal direction, and about 1 1/2 sideways.
Jeff"
"Thanks guys, because while I
"Thanks guys, because while I mounted my shaft about 1" further back than the boat originally had it (is that an issue too?) that means the most I can adjust is push the v-drive 1" forward, and 1" isn't much help!"
"Danny,
From face of bellho
"Danny,
From face of bellhousing to front of engine block ("approximates" per Mopar Performance Engine Manual) .......
small block 22"
big block 23.4""
