MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Join Date
    Nov 2009
    Location
    stockport
    Posts
    5
    Default "ser no 676b 40718, not been r
    "ser no 676b 40718, not been run for 18months or so, fired up after cleaning plugs and fresh fuel, had it in a big barrell, no water flow from hole?, is this impeller or does it need messing with? help"
  2. #2
    Join Date
    May 2007
    Location
    Ireland,the only country in the world you can go North to go South
    Posts
    1,929
    Default "If it hasn't been run for
    "If it hasn't been run for 18 months then it's a fair bet that the impeller hasn't been changed in the last two years,so it's due a change,plus it has probably perished sitting about out of use.
    When you drop the lower unit,blow some air down the tell tale or poke some strimmer line down"
  3. #3
    Join Date
    Dec 2008
    Location
    Victoria, B.C., Canada
    Posts
    645
    Default "lee..use a thin piece of plya
    "lee..use a thin piece of plyable wire up the tell tale hole...if its been in the salt..it plugs there very easily. You may want to change the impeller anyway, but it may just be plugged."
  4. #4
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default yep clean the hole use comp
    yep clean the hole
    use compressed air also
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
Similar Threads
  1. 40hp Mariner needs water pump
    By dstrbd223 in forum Mercury Mariner Outboard Forum
    Last Post: 03-10-2010, 08:17 PM
  2. 1989 40 hp marineryam electric problems
    By barb in forum Mercury Mariner Outboard Forum
    Last Post: 12-21-2009, 08:30 PM
  3. Trickle charge
    By dinger in forum Mercury Mariner Outboard Archive
    Last Post: 11-02-2009, 11:50 AM
  4. Battery Trickle Charger
    By kitjp1124 in forum Volvo Penta Gas Archive
    Last Post: 06-10-2008, 06:29 PM
  5. 1964 Johnson 40HP No Water
    By paulb in forum Outboard motors archive 2000-2004
    Last Post: 06-28-2002, 09:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
