MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
Thread: Help
  1. #1
    Join Date
    Nov 2009
    Location
    stockport
    Posts
    5
    Default "i have a dell quay dory with
    "i have a dell quay dory with mariner outboard, need impeller, all i can see on engine cradle is 676b 40718, and on engine itself"67602" also y-1 ? means nothing to me, any help on year etc and where to find impeller, much appreciated"
  2. #2
    Join Date
    Jun 2009
    Location
    New Plymouth,Taranaki,New Zealand
    Posts
    287
    Default "Hi Lee,i get 1979-80 yamaha b
    "Hi Lee,i get 1979-80 yamaha based mariner 40hp?.yamaha agents may have parts"
  3. #3
    Join Date
    May 2007
    Location
    Ireland,the only country in the world you can go North to go South
    Posts
    1,874
    Default "Hi lee, That number, 676B
    "Hi lee,
    That number, 676B 40718, would make it a 1980,that is if it was a 40EL . So you need to post the HP.The one thing is sure is that it is a yamaha built mariner.If Graham is looking in he will be able to give you the yamaha equivalent,he's the mariner expert."
  4. #4
    Join Date
    Nov 2009
    Location
    stockport
    Posts
    5
    Default "great, thanks a lot<[img]"htt
    "great, thanks a lot"
  5. #5
    Join Date
    Nov 2009
    Location
    stockport
    Posts
    5
    Default its a 40hp
    its a 40hp
  6. #6
    Join Date
    May 2007
    Location
    Posts
    1,874
    Default "AS Ian says take the impeller
    "AS Ian says take the impeller to a yamaha shop and they may have one,mid 70&#39;s yamaha 40hp."
  7. #7
    Join Date
    Nov 2009
    Location
    stockport
    Posts
    5
    Default "will it be the impeller?, its
    "will it be the impeller?, its been stood around 18 month, no water trickles out of hole~?"
  8. #8
    Join Date
    Jun 2009
    Location
    Posts
    287
    Default "hi,i put electric drill onto
    "hi,i put electric drill onto driveshaft,with g/box submerged in bucket of water,and fire it up and see how much water flow/presure comes out hole where pipe normally goes in.make sure its in nuetral,and that the intake is submerged.saves assembling/starting/diassembling.that will tell you if impellor is worn or not.they should be clean/firm but flexible.no bits missing"
  9. #9
    Join Date
    Jun 2009
    Location
    Posts
    287
    Default "forgot to say,take g/box off
    "forgot to say,take g/box off first.helps"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
