25 3 cylinder evenrude water pump
"You are a bit short of info o
"You are a bit short of info on the engine model, but suggest you remove the water-screens on lower unit!
Split the shift-rod, push UP the upper nut and remove the plastic keeper on the rod. Then down with gear case."
Tell us the year and/or the mo
Tell us the year and/or the model number.
When you say no shifting rod you mean it has electric shift? If so the gearcase will still sparate from the leg as normal but you will have to disconnect the wiring.
Can't identify a 25 with electric shift though
Year/model number ??
