MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
Thread: Pull cord
  1. #1
    Join Date
    Sep 2006
    Location
    n.las vegas, nevada, usa
    Posts
    74
    Default "i have a 1975 7.5 mercury out
    "i have a 1975 7.5 mercury outboard serial#6384520 that the handle on the pull cord broke and the rope slipped into the sheave and lost the tension on the recoil spring..does anybody know how to fix this or do i have to take it to the dealer,any help would be greatly appreciated.........."
  2. #2
    Join Date
    Jun 2009
    Location
    New Plymouth,Taranaki,New Zealand
    Posts
    287
    Default "Hi Gerald,if you can take the
    "Hi Gerald,if you can take the pull start housing off the motor,you maybe able to catch the end of the rope,tension up the spring by revolving the disc with the rope in the cutout[should have one],then when youve got a bit of tension[about 3 revolutions should do it]poke the rope[tip,burn the end of the rope with cig lighter,then stub out]back thru the hole if u can.its usually only the last 4 inches that needs cutting off.if the rope needs replacing,pull the old rope right out till the end,then hold the disc with your other hand,and u shoul be able to grab the knot,pull it out bringing the whole of the old rope with it.then put the new rope in[burn the ends]until it pops out where the knot was,tie a new knot,then let the spring tension retract the new rope in.dont lose the end.try that"
  3. #3
    Join Date
    Sep 2006
    Location
    Posts
    74
    Default i've tryed that but i thin
    i've tryed that but i think the spring jumped off the spring post when the cord slipped back into the sheave..........
  4. #4
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,290
    Default "You're screwed, my friend
    "You're screwed, my friend.
    When (if) you take it apart, do yourself a HUGE favor and make a diagram of which way the spring wrapped. That way, as you attempt to stuff a new one in, it'll go the right way.
    It's a job none of us look forward to, I can assure you!
    Jeff
    PS: This is one job you might like to hand off to a dealer and bite the bullet."
  5. #5
    Join Date
    Feb 2009
    Location
    perth, wa, Australia
    Posts
    956
    Default Jeffs right take it to a deale
    Jeffs right take it to a dealer.. but they are a piece of cake to do if you get shown how to do it the right way
Similar Threads
  1. OLD 6hp Pull Cord
    By mikebenghp in forum Johnson Evinrude Outboard Archive
    Last Post: 12-01-2009, 01:39 PM
  2. How to replace pull cord on 50hp
    By tassie in forum Yamaha Outboard Archive
    Last Post: 03-23-2009, 04:05 AM
  3. 98 pull cord
    By red_dwarf in forum Mercury Mariner Outboard Archive
    Last Post: 02-19-2008, 08:54 PM
  4. How long should the pull cord be
    By 102030 in forum Mercury Mariner Outboard Archive
    Last Post: 10-21-2006, 09:14 AM
  5. Pull cord size for evinrude 15
    By jdot123 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-26-2003, 01:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
