MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
  1. #1
    Join Date
    Jan 2009
    Location
    blanchard, ok, usa
    Posts
    76
    Default Hi everybody.. how do you inst
    Hi everybody.. how do you install R.S. rec. to reduce charge volts going to batt. on 1987 90hp 3 cyl merc????
    arcrat..
  2. #2
    Join Date
    Nov 2005
    Location
    Chesapeake, Va, US
    Posts
    1,111
    Default What exactly are you trying to
    What exactly are you trying to do? A rectifier converts AC to DC to charge the battery. It isn't a regulator.
    Bill H PTC USN Ret
    A manual is a cheap investment.
  3. #3
    Join Date
    Jan 2009
    Location
    blanchard, ok, usa
    Posts
    76
    Default Hi IBN i read on this site. t
    Hi IBN i read on this site. that if your batt over chargeage R S rec would drop charge volts... mine charges 16+ volts .I thought it might be acheap fix
    THANKS arcrat
  4. #4
    Join Date
    Nov 2005
    Location
    Chesapeake, Va, US
    Posts
    1,111
    Default "The most common causes of hig
    "The most common causes of high voltage in a non-regulated system is bad cable connections, corroded lugs, and bad or wrong type battery. You must use a marine battery. You can add a regulator but I have lost the part no. for it. Perhaps someone else can chime in here."
    Bill H PTC USN Ret
  5. #5
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,657
    Default A rectifier won't do a thi
    A rectifier won't do a thing. You need a voltage regulator of some kind. Late model OBs use them.
    Jeff
  6. #6
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default post serial number and i can p
    post serial number and i can post part numbers
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  7. #7
    Join Date
    Jan 2009
    Location
    blanchard, ok, usa
    Posts
    76
    Default "OB174136.. THANKS JIT,FASTJEF
    "OB174136.. THANKS JIT,FASTJEFF,IBNFISHN....
    THANKS AGAIN arcrat"
Similar Threads
  1. engine noise on radio
    By mwb in forum Boat Electrical Systems
    Last Post: 10-18-2010, 01:03 PM
  2. 1997 merc 115 hp radio/cd cuts out
    By bbuczl in forum Mercury Mariner Outboard Forum
    Last Post: 06-17-2010, 11:48 AM
  3. radio towers
    By rrodney in forum Johnson Evinrude Outboard Forum
    Last Post: 05-06-2010, 07:36 PM
  4. VHS Radio
    By nydoug in forum Miscellaneous marine engine topics
    Last Post: 10-29-2008, 08:49 PM
  5. Impulse Loran C model 3001 Postioning Radio
    By mitch in forum Archive 2003-2007
    Last Post: 09-08-2006, 03:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
