"Hey everyone,
I could use
"Hey everyone,
I could use some help. I have a 1984 BF100 10hp 4-stroke outboard. It has never given me any problem until now. I recently dumped the old gas and refilled the tank with new gas and I ran it at least a half an hour afterwards. It is on a sailboat and it doesn't get much use. After about two weeks, I started it and it ran fine for about 20 to 30 seconds and then it died. I had left the gas tank out in the cockpit and it had rained quite a bit so I figured I got some water in the fuel. I drained the carb and still no progress. I pulled the engine and brought it home. It would fire immediately if I shot ether into it so I assumed either water in the gas or trash. I ran fresh gas through the carb, cleaned the plugs and still no progress. I pulled the carb and cleaned the main jet and the idle jet. There was some gunk in the bowl, which I cleaned. The inlet needle looked fine and fills and shuts off fine. I reinstalled and no progress. It will run with ether but not with the fuel. I could feel some light pull from the intake manifold so I don't think it is low compression. My only guess is that something is still clogged on the carb.
Any ideas? I thought once I had spark I was home free, but I ran out of daylight and I would like some professional advice if you can enlighten me.
Thanks,
Jeff"
I could use
"Hey everyone,
Thanks,
Jeff"
