N
Neil Millar
Guest
When flushing motor the enging
When flushing motor the enging buzzer goes off after say 5 minutes at idle. the left hand cylinder bank from rear of motor (Lower bank ) is fine however the right hand bank is hot to touch. their is a reasonable flow form the P indicator and the water is cool. If I increase the revs even slightly the right bank cools down almost imediately and is the same temp as left bank and water pressure is even higher out of p indicator.
I am thinking it could be a stuck thermostat in the right bank as if it was the water pump both cylinder should be hot or at least the water comming out fo th indicator should be hot?? Is this right?
can i test the thermostat theory by removing and trying or could this cause damage running without the thermostat?
