Atomic Four 30 HP 1979
  • Thread starter Hans Van Keulen
  • Start date
H
Hans Van Keulen
Guest
"I need to replace the rear tr
"I need to replace the rear transmision seal and bearing, because oil is leaking from seal. Can this be done without pulling the engine out of the sailboat? This engine has a inspection plate which is used to adjust the forward and reverse gears.I also remove this inspection plate when I change the oil.Can someone tell me how best to do this job or where I can find info how to do this repair.The info is not in my Atomic Manual."
