M
MarkVN
Guest
This is a mess
I too recently
This is a mess
I too recently had the problem with my port engine after running up to 180 degree operating temp and under way would bog down after I tried to push the throttle back up above 2000 RPM's I never cleaned the screens but have replace the filters.
Here is the new problem... I took off the Throttle Body (Dont ask me why) looking for corrosion gum clogging whatever... Put it back on and the engine started with no problems... The next time I started the engine would not idle down from 2200 RPM's. I can't seem to figure out how to slow the engine down.. Would the IAC cause the engine to idle up to 2200 RPM's?
I too recently
This is a mess
