"The warning buzzer will sound
"The warning buzzer will sound on overheat,low oil and blocked oil filter. Sounds like you have solved your carb problem with just in times help.This is probably different. I assume motor is a 2 stroke, can it be run on premix? Is the cooling waterflow ok?
Good luck!"
Good luck!"
