Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2006
    Location
    Saint Petersburg, Florida, USA
    Posts
    19
    Default "I have a V-8 Mercruiser engin
    "I have a V-8 Mercruiser engine that when I start it, it makes this loud grinding or squeaking noise (metal to metal. When I accelerate the engine, it stops. When it is back to idle, it squeaks again. I thought it was the power steering pump because it happened before when it went dry but when i check it this time, it had fluid and it appeared fine. Any ideas or suggestions out there?
    Thanks in advance"
  2. #2
    charli's Avatar
    charli Guest
    Default Is the alternator belt tight?
    Could the power steering pump have gone bad from lack of fluid?
    Try removing each belt and see in the noise goes away.
    Grinding sounds like one of the pulleys is hitting something if the noise is infact from the front of the engine.
    Also check the crank balancer.(lower pulley mount) These do not fail often but you never know.
  3. #3
    Join Date
    Feb 2006
    Location
    Arlington, VA, USA
    Posts
    952
    Default sometimes i get a loud expensi
    sometimes i get a loud expensive sounding screaming noise each time i go to my boat. turned out to be my wife.
  4. #4
    Join Date
    Nov 2002
    Location
    Mullica Hill, New Jersey, United States
    Posts
    1,810
    Default Sounds like it's time to t
    Sounds like it's time to trade up!
  5. #5
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,439
    Default The boat or the wife! Jeff
    Jeff
  6. #6
    Join Date
    Aug 2006
    Location
    Calgary, Alberta, Canada
    Posts
    2,426
    Default Maybe both? Rod
    Maybe both?
    Rod
  7. #7
    Join Date
    Feb 2006
    Location
    Arlington, VA, USA
    Posts
    952
    Default "renaming my boat "the fie
    "renaming my boat "the field office" so now i can grab my brief case and confidently state: "honey, I'm headed to the office!" or "I really need to get into the office today" (sunny saturday)"
  8. #8
    Join Date
    Feb 2009
    Location
    , nassau, bahamas
    Posts
    8
    Default "i HAVE A REGAL WITH A GM 181
    "i HAVE A REGAL WITH A GM 181 3.0L 4 CYCLINDER AND FIRST I KEEP NOTICING THE ALTERNATOR BELT KEEPS COMING OFF, ALSO I HEAR A LOUND CONTINUOIS NOSE COMING FROM THE FRONT OF THE ENGINE , ANY SUGGESTIONS WOULD BE APPRECIATED."
Similar Threads
  1. Wonbt accelerate and has loud air spray noise
    By captain_yarrr in forum Mercruiser Sterndrive Archive
    Last Post: 09-27-2009, 05:40 PM
  2. 57 mercursier very loud metal clanking noise
    By kenkee1 in forum Mercruiser Sterndrive Archive
    Last Post: 06-10-2009, 12:35 PM
  3. Engine starts but has loud metal clanking sound
    By joshclark0331 in forum Mercruiser Sterndrive Archive
    Last Post: 05-22-2009, 10:11 PM
  4. MD11C Loud Banging or popping noise
    By riburton in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 05-12-2008, 10:56 AM
  5. Loud squeaking noise 43 LX Mercruiser Alpha one
    By helicorp in forum Mercruiser Sterndrive Archive
    Last Post: 05-10-2007, 11:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
