Results 1 to 3 of 3
  1. #1
    Kevin E.'s Avatar
    Kevin E. Guest
    Default " I went to remove the lower u
    " I went to remove the lower unit on a 1989 evinrude
    150 V6, to replace the water pump. The lower unit
    seperated easy enough, but the tech manual had me remove the bolt at the top of the shift rod connector, I did that and the "barrel type clamp" that rotates the shift rod up and down at the base of the power head, would not fit through the hole in the housing to lower the whole thing down. That clamp does not appear to be removable, since it is pinned with a very small pin to rotate on and cannot be reached with human hands.
    If someone has some advice or has done this before, I would greatly appreciate the help.
    Kevin
    Clinton, Connecticut "
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,228
    Default "Kevin.... There should be a 3
    "Kevin.... There should be a 3/8" hex head bolt screwed into the side of that clamp, which is actually a long shoulder bolt type screw (a pivot pin). Sounds like you removed the bolt that faces forward, the one that clamps the shift lever to the shaft. The 3/8" shoulder bolt is reached by using a long 1/4" drive extension with a 3/8" flex socket. You'll also need the long flexible "finger" type grab tool to extract and insert that shoulder bolt.
    Joe[img][/img]"
    We occasionally have questions. If you fail to answer, it may affect ours.
  3. #3
    Janice Chrans's Avatar
    Janice Chrans Guest
    Default I removed the pivot pin by ac
    I removed the pivot pin by accident and to cannot get it back in - please help!
Similar Threads
  1. 91 30hp Evinrude Lower Unit removal
    By hammy67 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-06-2009, 12:13 AM
  2. 25hp Evinrude lower unit removal
    By mhare in forum Johnson Evinrude Outboard Archive
    Last Post: 03-24-2007, 09:53 PM
  3. Removal of Lower Unit 95 Evinrude
    By Shirley Johnston in forum Johnson Evinrude Outboard Archive
    Last Post: 09-09-2006, 11:07 PM
  4. Lower unit removal on 1977 Evinrude
    By wrvv in forum Johnson Evinrude Outboard Archive
    Last Post: 05-23-2006, 01:46 PM
  5. 1975 evinrude 85 hp lower unit removal
    By O.R EVERETT in forum Johnson Evinrude Outboard Archive
    Last Post: 03-21-2006, 05:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
