Click for Detroit Diesel manuals!
Results 1 to 5 of 5
  1. #1
    ANDRE LINDSEY's Avatar
    ANDRE LINDSEY Guest
    Default " Hi I am about to buy a 6v-92
    " Hi I am about to buy a 6v-92gm deisel. I am a rank amateur with engines, and looking for a basic checklist of things to check before making the purchase..
    Andre "
  2. #2
    Kim Boehm's Avatar
    Kim Boehm Guest
    Default " Probably worth your while to
    " Probably worth your while to have an experienced diesel mechanic, preferably one with GM experience, to check the old girl over. A sea trial is also recommended. Also if totally unfamiliar with boats, and purchase price is say more than 10K, a survey would be in order. Check around for a good surveyor or check Yellow pages under "Boat Surveyor". It is usually well worth the cost. If the seller balkss at these ideas, walk away from the deal. Good luck, and keep us posted, Kim "
  3. #3
    Join Date
    Jun 2000
    Location
    Forest Dale, VT, USA
    Posts
    1,681
    Default "Andre, That is good advise
    "Andre,
    That is good advise from Kim. Some surveyors have web sites that have information about what they do and what they look for... he are some links... but you should choose a surveyor that is local to you... maybe try to get one recommended to you by someone other than the seller!
    You also might want to consult one of the many general books available on diesel engines, so at least you will understand the terminology.
    Good luck.
    Andrew"
    Andrew Menkart
    MarineEngine.com
    "There is no situation in which knowledge is more truly power than at sea."
    - Lord Brassey
  4. #4
    poker casino615's Avatar
    poker casino615 Guest
    Default "***** ****** [url=""]***** 93
    "***** ****** ***** 93"
  5. #5
    poker casino398's Avatar
    poker casino398 Guest
    Default "***** ****** [url=""]***** 27
    "***** ****** ***** 276"
Similar Threads
  1. What to check when buying an OutboardHelp Please
    By enginesilo in forum Johnson Evinrude Outboard Archive
    Last Post: 06-18-2008, 02:50 AM
  2. What to check when buying a boat with a Mercruiser
    By enginesilo in forum Mercruiser Sterndrive Archive
    Last Post: 06-02-2008, 12:58 AM
  3. Buying a Boat
    By smokengun in forum Mercruiser Sterndrive Archive
    Last Post: 05-17-2007, 07:39 AM
  4. Advice on buying yanmar260hp diesel
    By kelly in forum Yanmar
    Last Post: 04-27-2003, 08:37 AM
  5. What to check on a 70HP Jonhson before buying
    By matt in forum Outboard motors archive 2000-2004
    Last Post: 08-13-2001, 01:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
