Results 1 to 4 of 4
  1. #1
    Join Date
    Mar 2006
    Austin, TX,
    Default Ho again My engine yamaha
    Ho again
    My engine yamaha 8hp has no impeller (rotted) what does it or should it do? whats its function.
  2. #2
    Default It pumps water to keep the en
    It pumps water to keep the engine cool !
  3. #3
    Join Date
    Nov 2005
    Default " Easy there sparky [img][/img
    " Easy there sparky [img][/img].. stephen, sparky has it right, I'm just going to add my two cents. The impeller on most outboards is going to be located over the driveshaft, just above where the driveshaft enters the lower unit. The driveshaft is allways spinning when the engine is running, so the engine allways has a supply of cool water. There is also going to be some type of tube above the impeller that will carry water up to the powerhead.
    Jon "
  4. #4
    Join Date
    Mar 2006
    Austin, TX,
    Default " thanks for your help for a b
    " thanks for your help for a biginner i done ok, i removed the lower unit and opened up the pump took out the impeller and cleaned it all up.
    I also chaned the zink as it was corroded cleaned out the pipes and it works great now :-) a constant flow of water.
    Stephen "
Similar Threads
  1. Water pump impeller kit OR pump impeller kit
    By freeportd in forum Honda Outboard Forum
    Last Post: 11-07-2010, 06:28 PM
  2. Impeller
    By tanker2221 in forum Volvo Penta Gas Engine Forum
    Last Post: 11-25-2009, 02:01 PM
  3. Should I go for a new impeller
    By edsidm in forum Mercury Mariner Outboard Archive
    Last Post: 09-20-2008, 07:05 PM
  4. Raw water impeller on 1971 318 rubber impeller blades in bits and pieces everywhere
    By Cody Street in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 07-24-2008, 11:15 AM
  5. Impeller
    By macomber in forum Yamaha Outboard Archive
    Last Post: 06-19-2008, 01:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
