MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    Default "The seals are shot in my 18 x
    "The seals are shot in my 18 xd's lower unit and I am thinking about doing them myself. Is this a complicated task? I have done some pretty involved mechanical work in the past without too much trouble but I don't want to crack this thing open to find I need special tools.
    Also, the recoil seems weak and struggles to draw the cord back up in cold temps (I do a lot of duck hunting). I have been told that this is a simple lubrication issue but I don't know what parts to lubricate and what to lubricate them with. I am planning on beggining the work this weekend so any input would be great!
    Chris"
  2. #2
    Join Date
    Jan 2009
    Location
    blanchard, ok, usa
    Posts
    76
    Default "One good starting point, woul
    "One good starting point, would be to invest in a manual. they have them on this web site. look at top of page!!!!!
    arcrat"
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,471
    Default "IF you are a reasonable mecha
    "IF you are a reasonable mechanic, and have the tools, the LU is not too bad to reseal. Just don't mess withthe bearings, or loose any shims.
    The recoil simply needs another wrap on the rope. Pull out some slack, then wrap the rope around the sheave one revolution. That increases the 'pull back'.
    Jeff"
Similar Threads
  1. 84 OMC 800 Seal Replacement
    By salt_fever in forum OMC Sterndrive and Inboard Forum
    Last Post: 03-14-2010, 04:05 PM
  2. 1983 402 recoil starter pawls not engaging
    By evinrude_boater in forum Mercury Mariner Outboard Archive
    Last Post: 08-28-2009, 10:10 PM
  3. New to forum 1983 Renken omc 4cyl Upper gearcase lube milky
    By Thomas Cinalli in forum OMC Sterndrive and Inboard Archive
    Last Post: 01-23-2007, 08:25 PM
  4. 1981 Johnson Gear Lube Replacement #J140TLCIM
    By lizzy5429 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-01-2006, 07:10 PM
  5. Lube points 1983 40 hp merc
    By greg1 in forum Mercury Mariner Outboard Archive
    Last Post: 01-01-2006, 12:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
