1999 115 hp 2 cycle will not start
upperkey
"Engine was run throughout the
"Engine was run throughout the day, stopped for a few hours, then would not restart but does turn over fine.} Still will not start after getting it home, seems to be getting fuel. Ignitition problem?"
"Ok,I seem unable to locate th
"Ok,I seem unable to locate the switch box. This may be a dumb question but where is it? Thanks."
"'99 is CDM. Not T-Bolt. I
"'99 is CDM. Not T-Bolt. If you burnt up any yellow wiring, than the stator and the rec/reg is probably bad. So is the battery, I'll bet."
"After conducting tests on the
"After conducting tests on the stator, according to the repair manual it appears to be bad. And yes the rec/reg as well. Do I need the flywheel removel tool specified in the manual or are there other options? Thanks for your help."
"Ok, replaced stator and reg/r
"Ok, replaced stator and reg/rec. Engine cranked up but is running very rough and unable to increase rpm's without stalling. Reverified connections and placement of components. Maybe also have a bad coil, but wouldn't engine still run on 3 cyls? Any thoughts? Thanks."
