MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 6 of 6
  1. #1
    Join Date
    Nov 2009
    Location
    Hibbing, MN, United States
    Posts
    4
    Default This motor has trouble startin
    This motor has trouble starting because it does not seem to have a throttle idle lever. The choke works off of the remote but I do not see any simple 'lever' to rev the throttle to start.
    I have to pull the cover and give a shot of starting fluid to start it and then it just barely stays running. Quits many times.
    Is there an idler on the remote shifter?
  2. #2
    Join Date
    May 2007
    Location
    Ireland,the only country in the world you can go North to go South
    Posts
    1,960
    Default "I suggest you quit using star
    "I suggest you quit using starting fluid,no oil in it,no cyl very soon. Is there a button in the center of the shift lever? If there is,when in neutral push in the button,this disengages the gear lever and allows the throttle to open."
  3. #3
    Join Date
    Nov 2009
    Location
    Posts
    4
    Default Thank you. Yes...the Ethyr is
    Thank you. Yes...the Ethyr is not a solution for sure.
    I have looked at the obvious..for the button..somewhere..anywhere. I am baffled. Probably need to let an expert have a look.
    Wondering if anyone has a similar motor with ..'the answer'
  4. #4
    Join Date
    Nov 2009
    Location
    Posts
    4
    Default OK..I will get a photo. Thanks
  5. #5
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,656
    Default Some throttle have a deal wher
    Some throttle have a deal where you hit a buttont to separate the throttle from the shifting. That way you can idle it up. Look for a button or ?? near the handle.
    Jeff
  6. #6
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default you should have a warm up leve
    you should have a warm up lever or start in neutral
    rebuild the carbs and fuel pump and change plugs
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
Similar Threads
  1. 1963 throttle lever pivot
    By chilock in forum Johnson Evinrude Outboard Forum
    Last Post: 12-05-2010, 09:55 PM
  2. Throttle lever
    By SeaSprite195 in forum Mercruiser Sterndrive Forum
    Last Post: 08-07-2010, 05:03 PM
  3. 28 spl control lever problem Throttle lever
    By ardy in forum Johnson Evinrude Outboard Archive
    Last Post: 04-22-2009, 08:13 AM
  4. Removing Throttle Lever Assy from Control Box Johnson 1989 110HP
    By mr_johnson in forum Johnson Evinrude Outboard Archive
    Last Post: 03-22-2008, 08:57 AM
  5. Throttle lever ringvold bob hystat please help
    By 88fourwinns in forum OMC Sterndrive and Inboard Archive
    Last Post: 11-13-2007, 08:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
