Oil on spark plugs
arcrat
Hi to everybody. oil on plugs
Hi to everybody. oil on plugs does this mean not running hot enought? I can hold my hand on powerhead after running hard. thanks you very much....arcrat
More infor. recent overhaul. r
More infor. recent overhaul. ran 30-50 gals of fuel for brake in . double oil 100-1 . carbs set at 1 1/5 turns on jet adj. run great. 3 cyl 90hp.1987 model. smokes alot at idle. do you think if i adj jets to 1.1/4 would fix it. thanks for any reply. arcrat
Repost I put 32oz to every 6ga
Repost I put 32oz to every 6gal of gas. my bad. I Posted 100 to 1but it was 25 to 1. thanks for the sec. e mail. ok what obout the oil on plugs. after running hard....arcrac
And the oil injection system w
And the oil injection system was also putting oil in! It's a miracle it even ran.
Jeff
"Ok Stubborn Jeff.hears the de
"Ok Stubborn Jeff.hears the deal. I been running 16 oz per 6 gals , is it posible that there might be a lot of oil in the tank? to be haveing oil on plugs?. Thanks Jeff.
arcrat"
"It's possible, but you mi
"It's possible, but you might have a flooding carbs problem as well.
Normal Jeff"
Thanks Jeff.. I well check tha
Thanks Jeff.. I well check that out. Might be back for help on Carb topic... Thank again Normal Jeff....
arcrat
