fastjeff
Gold Medal Contributor
"Y'all might get a kick ou
"Y'all might get a kick out of this:
Merc 25. Wanted to calibrate my built in tach with a portable Tiny Tach. EMF interference screwed up the readings on the Tiny Tach, so I did what I always do: I wrapped the other plug wire with aluminum foil to block the interfering EMF.
Unfortunately--like a jerk--I didn't shut the motor down and do it right, I merely draped the foil over the top plug wire (with the Tiny Tach lead wrapped around the lower wire). Motor started skipping badly then died--no spark! The EMF had jumped from the spark plug wire to the primary wires of the coil and into the spark box. Groan!
So what was blown out? Obviously, the sensitive spark box, right? Wrong. It's fine. The charging coil is what went! Imagine that.
Thanks to my good buddy, who lent me a spare one, the problem is resolved.
Jeff"
Jeff"
