"OK, here's my situation.
"OK, here's my situation. Went out fishing couple days ago, ran down the river to the mouth of the lake, about 1/2 hr at WOT fished for about 1 hr and had a problem starting motor, had to keep priming to keep running after running OK went back up river for about 20 min WOT, fished for 2 more hours and decided to head home, again motor wouldn't start unless primed several times, started to head out and stalled, started again and found that my buddy had to keep pumping primer bulb to keep running, after about 10 min at 3500 RPM the hi-temp alarm started sounding,tell tale is flowing good, we shut down and checked the engine, heads didn't seem to be that hot (river water temp 42 deg) started back up pumping primer all the way and again alarm went off. we decided to shut down and paddle to shore. ended up getting a tow back to launch by a fellow boater (boaters are the nicest people). Just wondering if maybe my fuel pump may be shot and by pumping the primer we were getting fuel OK but no oil, any thoughts."
