Results 1 to 15 of 15
  1. #1
    Join Date
    Aug 2009
    Location
    Sydney, NSW, Australia
    Posts
    211
    Default Trailer skids instead of rollers
    "Off topic, but a lot you guys should know.
    Im tired of trailer maintenance, and thinkin of gettin rid of the rollers. Trailers about to get a major o-haul ne way. (rust)
    Thinkin of goin to plastic/nylon/teflon blocks down the centre, or maybe a single long strip straight down the centre of the trailer... maybe a V shape to help centre boat to trailer. boat weighs about 2000 kgs.
    The boat, Fibreglass, 23ft Bertram, Mercruiser 260.
    Trailer now, lotsa 12in centre keel rollers with those wobbly wheels down each side where the original bunks were.
    Im concerned about friction with solid blocks, but something else must be better than rollers that lock up as soon as they feel the weight of the boat. Ive seen trailers with out rollers, anyone have experience with this?"
  2. #2
    Join Date
    Oct 2009
    Location
    ndola, copperbelt, zambia
    Posts
    5
    Default "TRY 4 PLANKS COVERED WITH IN
    "TRY 4 PLANKS COVERED WITH INDUSTRIAL CARPET TILE OR 1" FELT, BONDED WITH BOSTICK AND TACKS."
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,025
    Default "I don't think you'll
    "I don't think you'll be happy with skids after having rollers. I'd say invest in premium grade components. haven't trailered in a while but never had any issue in the 10 years we did once we had 'good stuff'. The 'economical stuff' just wouldn't stand up to the elements, especially around salt water.
    if you decide to keep the rollers, look for a packaged deal - it will be cheaper, in the long run, to do it all at once."
  4. #4
    Join Date
    Dec 2008
    Location
    Victoria, B.C., Canada
    Posts
    645
    Default "The guys up here who have the
    "The guys up here who have the skids like them, but I still prefer rollers. All the bunk guys have to sink their trailers..often to the point of the rear wheels of the tow vehicle being in the salt on a shallow ramp.....not good for the rear brakes!! I love my Shoreland'r, great roller system, dropped axles and disc brakes standard equipment! I have a 22 ft Seasport it rolls off with a slight push everytime...have to hold it back it goes off so fast."
  5. #5
    Join Date
    Dec 2007
    Location
    Ocala, FL, USA
    Posts
    89
    Default "Check out this site for good
    "Check out this site for good information on teflon bunks. A friend of mine had his boat slide off the trailer on the ramp so pay close attention to the advise to keep the bow strap fastened until the boat is in the water.
    http://www.wmi.org/bassfish/bassboar...age_id=19337 8"
  6. #6
    Join Date
    Aug 2009
    Location
    Posts
    211
    Default "Guys Thanks for the replie
    "Guys
    Thanks for the replies, sorry i didnt reply sooner, I lost the post. Bunks im thinking of using are called DURABUNKS, and feature on DURALUM trailers.
    http://www.duralum.com.au/html/features.html
    I believe they are solid POLY. this stuff is slippery and does not require carpet. Having trouble sourcing the durabunk skids.
    I dont want moving parts on trailer, anymore."
  7. #7
    Join Date
    Aug 2009
    Location
    Posts
    211
    Default .
  8. #8
    Join Date
    Feb 2010
    Location
    Lake Camanche, CA, USA
    Posts
    26
    Default Re: Trailer skids instead of rollers
    I had a 21' Trophy on rollers which was a pain to load. Switched trailers to bunk boards then installed 'poly' type strips on the 2"x4" boards. Best thing I've ever done. But don't unhook until the stern is in the water otherwise your boat maybe sitting on top of the concrete ramp. Here's a link on how to install: http://www.rockettrailers.com/pdf/bu...7107-57108.pdf
  9. #9
    I have found that if you launch in the shallower ramps and if you are used to rollers there better, if you go on steep ramps the bunks are better. just my opinion.
  10. #10
    Join Date
    May 2010
    Location
    Upcountry, S.C.
    Posts
    179
    Having looked at a dozen and a half used boats for sale on trailers, It appears with age, the rollers leave indentations in the hull, bunks don't.
  11. #11
    Join Date
    Jul 2009
    Location
    , Orygun, USA
    Posts
    151
    I am unable to post a new thread here, and this screen is ginormous, cant seem to get it set right. In the mean time Ill just use this thread to get somebody thinkin on my trailer problem
    Ive got a 68 easy load 25 ft trailer with a 5000 pound fiber form crusier on it that needs a new spring or at least a new main leaf. Nobody around here or on the net so far seems to be able to help me. The spring is just clamped in the center to the frame with both ends flat and floating. Got any idea where I might be able to finf a new leaf or a whole spring???
  12. #12
    Try your local truck spring repair shop or ask your car mechanic/RV store where they get it done.Try the Yellow pages in phone book.I just had some leafs on a travel trailer done, very reasonable and done correctly.They would also sell them to you if you wanted to do it yourself.NAPA might have them but you will need to measure and possibly have load rate of leafs.
    Goobs says hey
  13. #13
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,710
    Rrough roads with rollers on the trailer have been known to damage the hulls on some boats.--------Some hulls are not designed for extreme point loads when you hit a bump at speed.----------Bunks are best on rough roads.
  14. #14
    Join Date
    Feb 2010
    Location
    Posts
    26
    I overhauled my bunk board last year and attached Poly bought at TAP's Plastic. CAUTION: Do not remove your bow hook until you're at the bottom of the ramp...these strips are slick
  15. #15
    Join Date
    Oct 2006
    Location
    Lake Jackson, TX, USA
    Posts
    307
    Can grit imbed in the bunks and scratch the hull?
Similar Threads
  1. Trailer up but no tilt up
    By jafma in forum Mercruiser Sterndrive Archive
    Last Post: 05-18-2008, 10:35 AM
  2. Trailer question
    By fishon10 in forum Mercruiser Sterndrive Archive
    Last Post: 04-30-2008, 11:16 AM
  3. Trailer tires dry rot
    By dave_kirk in forum Archive 2003-2007
    Last Post: 10-24-2007, 08:20 AM
  4. Trailer Brakes Anyone
    By guyjg in forum Mercruiser Sterndrive Archive
    Last Post: 10-23-2007, 06:39 PM
  5. Trailer winch
    By mopar43035 in forum Archive 2003-2007
    Last Post: 04-19-2007, 08:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
