MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default "Hi Bought this boat used and
    "Hi Bought this boat used and have no owners manual. What is the proper procedure to start engine. It has no choke. Hard cold starting, after finally starting will start fine rest of day. Put new primer bulb on no help. Any thing to check? Can hear click when push key in. Thanks everyone."
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,114
    Default "Hello Bruce - the XR6's w
    "Hello Bruce - the XR6's which are parts of Merc's "Black Max" series have what's called an "enrichment system" in place of a traditional choke.
    The system kinda "leaks" fuel down to the intakes via small tubes which are controlled by a little solenoid valve.
    To operate it you turn the ignition key to ON (but not all the way to start) and then push the key in and hold for a few seconds. This sends an electric current to the solenoid, forcing it open and then gravity takes over.
    Depending how well it works on your particular motor you may have to keep the key depressed for 5-10 seconds on a cold start.
    Since you are hearing the click (solenoid activating), at least you know it's getting power and is (probably) opening - however, you still could have a clogged line to or from the solenoid itself.
    So I would start with depressing the key for various lengths of time (start at about 5 seconds and work up from there), however, if you get much past 10 without any noticable improvement I would investigate the little fuel lines on the enrichment system..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Default "Thanks a lot, Graham. This in
    "Thanks a lot, Graham. This info helps a lot. Much better starting now. Still think I have small problem. I was fishing Lake Murray Friday. Started ok at dock. About 1 hour later tried to start again. You turn key, engine trys to start and but won't quite start, this went on for 15 or 20 attempts. Then it fired off ok. You said to check lines from solenoid, can I take compressed air and blow these lines out? Could 1 or 2 lines be clogged & cause this problem? Thanks again to Graham."
  4. #4
    Join Date
    Mar 2009
    Location
    Melbourne, Mornington, Australia
    Posts
    64
    Default Youj might be flooding it. If
    Youj might be flooding it. If the engine is warm you dont need to use the enriching system. This is my experience with my 150 black max
Similar Threads
  1. 1998 4.3 Hard Starting- cold or hot
    By mike1970 in forum Mercruiser Sterndrive Forum
    Last Post: 08-31-2010, 10:44 AM
  2. Hard cold starting weirdness
    By skytow in forum Crusader Marine Engine Forum
    Last Post: 06-02-2010, 12:56 PM
  3. Hard starting cold
    By lpc1737 in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-05-2008, 11:35 AM
  4. 75hp Merc 2002 ELPTO hard starting when cold
    By fred23987 in forum Mercury Mariner Outboard Archive
    Last Post: 11-21-2006, 06:27 PM
  5. 130 HP Johnson Hard starting when cold
    By Rick S in forum Outboard motors archive 2000-2004
    Last Post: 07-06-2001, 12:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
