Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2009
    Location
    AJ, AZ, usa
    Posts
    1
    Default I don't feel any disengage
    I don't feel any disengagement when the "lever" is moved to neutral and the prop still turns over. This engine has not been run for several years. Has good compression. Any help is wellcomed.... Any place recommended for a manual and parts? Mike
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    Default "Mike, sounds like the shift l
    "Mike, sounds like the shift linkage is stretched or broken.
    For parts and a manual you can try www.laingsoutboards.com - they specialize in the smaller "vintage" motors.
    Your particular model was produced by West Bend which was bought out by Chrysler which was bought out by Bayliner (U.S. Marine) which was bought out by Brunswick (who owns Mercury) - with the line actually finishing it's life cycle as a FORCE outboard.
    However, the parts and designs changed many times along the way and it finally died completely in the 1990's.
    It is however, a generic little motor from that time period and you may find that parts from other little generic's can be used/cobbled or retrofitted to work with it.
    Given that it's value is somewhat less than 100 bucks (in running condition), and there are hundreds of similar models available in the used market, I wouldn't invest alot of money in to getting it running..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    Oct 2009
    Location
    Las Vegas, Nevada,
    Posts
    2
    Default "Hey Mike. I just started up a
    "Hey Mike. I just started up a webfite specializing in parts for the earlier Elgins.
    www.Elginoutboardparts.com
    The mid 40s through mid 50s green ones in particular. Let me know if you need anything else, maybe some of the parts from the earlier ones will fit. If not, I make a lot of my own stuff so...if need be we can look into making your parts.
    With regards to the parts books there are a few vendors on Ebay that carry original stuff still in the plastic. I have his name somewhere and have gotten excellent books from the 50s!
    Thanks, mike O"
  4. #4
    Join Date
    Jun 2006
    Location
    Claremore, Oklahoma, USA
    Posts
    364
    Default "Franz at Franz Marine has par
    "Franz at Franz Marine has parts for some of the West Bend Sears motors.
    www.franzmarine.com
    Bill"
Similar Threads
  1. 1959 25hp Elgin fuel mixture
    By lewerke in forum Elgin Outboards
    Last Post: 07-13-2010, 12:07 AM
  2. What gear oil do I use in a 1959 Johnson sea horse 10 HP
    By hammer9 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-16-2009, 02:51 PM
  3. 1959 elgin 75hp
    By handyguy4u66 in forum Elgin Outboards
    Last Post: 07-12-2009, 09:56 AM
  4. 75 hp elgin need yearamp manual
    By brezy in forum Archive 2003-2009
    Last Post: 05-18-2007, 02:41 PM
  5. Looking for 1959 Chris Craft repair manual 283
    By Teri and Ivan Gelseth in forum Chris Craft Engine Forum
    Last Post: 12-05-2006, 10:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
