No Oil indicator light
regan
The no oil indicator light and
The no oil indicator light and buzzer is activated after running engine for ~20 minutes on 2001 150 Johnson. Oil is getting to the motor since I have taken off line and checked pressure with bulb. What is the next step??
Dan
"i thought...some of the other
"i thought...some of the other,.'pro's'....would have helped by now.....however...in my book,....an oil consumption test is absolutely,..next....when was the last time,u chged the filter in oil tank,and gotten the sludge out of it?...chg the entire oil line,if original.....chg filter,run oil consumption tests....if pump is original.......repl it,and do the above,..IF u want to stay on the oil system...its an individual's choice."
