Results 1 to 5 of 5
  1. #1
    Join Date
    Apr 2009
    Location
    Conestoga, Pa, USA
    Posts
    199
    Default "Hi men, I am tearing my 1987,
    "Hi men, I am tearing my 1987, 350 CID Mercruiser apart. The engine is still in the boat. How do I get the bottom bolt out of the starter (it connects the starter to the block). Is there a secreat way or do I need a special wrench? I can't see lifting the entire engine out of the boat to get the starter out! The reason being the engine will not crank over. I put a new battery in and it still won't crank. The wires show 12.7 volts on red to ground and 3.0 volts on the other side of the solinoid. Need help, Bob"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Replace the solenoid if you c
    Replace the solenoid if you can't get the starter off. I use a ratchet type Craftsman wrench. Tie a strap around the starter and snug it first so it hangs when you get the bolt out.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    Default "it is a 9/16" hex and you
    "it is a 9/16" hex and you need a deep dish socket, Snap on is preffered due to thinner socket wall and 3/8 drive, a short 3" extension and a lot of paitents!!!"
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
  4. #4
    Join Date
    Apr 2009
    Location
    Conestoga, Pa, USA
    Posts
    199
    Default "I'll give it a shot. Tha
    "I'll give it a shot. Thank you both, Bob"
  5. #5
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default deep dish ?? lmao.. someones h
    deep dish ?? lmao.. someones hungry.
Similar Threads
  1. Quick question
    By tbrodes in forum Crusader Marine Engine Forum
    Last Post: 07-21-2010, 08:08 AM
  2. quick question
    By j12j27 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-24-2010, 08:04 PM
  3. Quick question
    By grenacre2 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-11-2009, 02:58 PM
  4. Quick question
    By roederll in forum Johnson Evinrude Outboard Archive
    Last Post: 09-23-2008, 12:59 PM
  5. QUICK QUESTION
    By Tom Kozlow in forum Archive 2003-2009
    Last Post: 04-23-2004, 11:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
