Results 1 to 2 of 2
  1. #1
    Join Date
    Feb 2009
    Location
    Dunedin, Otago, New Zealand
    Posts
    5
    Default "I have had overheating issues
    "I have had overheating issues and here is what I have done so far. New impellor- the whole kit and water tube on my alpha 1 gen 2 leg. riser has been rodded out. new thermostat. new head gasket fitted,( no leaks here, i was hoping for a leak)new recirculating pump. New water shutter valve as last one melted. Engine will idle at normal temp but when in gear slowly increases at increased rpm until too hot. No water in cylinders, no water in oil.
    Guys I am all out of ideas! water appears to be coming in ok but perhaps not enough when revving higher. Help.
    Dave"
  2. #2
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    Default If incomming water is good the
    If incomming water is good then out going water or lack of is the problem. ( manifold) more suspect is the (risers)
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
Similar Threads
  1. Mercruser 3ltr 140hp engine number 2770087
    By pjdoor in forum Mercruiser Sterndrive Archive
    Last Post: 02-19-2009, 01:04 PM
  2. 3Ltr fumes
    By barrettd in forum Mercruiser Sterndrive Archive
    Last Post: 02-17-2009, 01:54 PM
  3. Winterizing Freshwater 3ltr Mercruiser Alpha One
    By robobru in forum Mercruiser Sterndrive Archive
    Last Post: 10-03-2008, 10:16 AM
  4. Shift Problem Mercruiser Alpha 1 3Ltr
    By dundle in forum Mercruiser Sterndrive Archive
    Last Post: 07-18-2006, 09:41 AM
  5. 1996 OMC Cobras w OMC 4cyl 3ltr engines
    By Johnny Q. in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-14-2001, 02:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
