Results 1 to 2 of 2
  1. #1
    Join Date
    Feb 2008
    Location
    Posts
    150
    Default The MerCruiser operation maint
    The MerCruiser operation maintenance and warranty manual states that timing at idle is not adjustable. How do you set the timing on a 350 mag mie after the distributer has been removed the engine spun then replaced back?
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,181
    Default "Distributor goes in just like
    "Distributor goes in just like the old ones.
    the adjustment procedure varies by distributor/ECU combinations. Basically, there is a jumper wire to enables a fixed timing mode. Once entered, the spec ignition advance is dialed and & the distributor locked down. Jumper removed and ECU controls timing from then on."
Similar Threads
  1. Timing Marks on Timing Decal
    By wemertz in forum Mercury Mariner Outboard Forum
    Last Post: 11-29-2010, 04:37 PM
  2. Timing Cover Missing Timing Marks
    By troym in forum Mercruiser Sterndrive Forum
    Last Post: 10-21-2010, 12:59 PM
  3. Eratic timing marks at idle with timing light. 1989 2.3 L
    By NewBoatGuyGeorge in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-23-2010, 11:39 AM
  4. 283 Chris Craft Timing How do I set timing
    By Jim Hawver in forum Chris Craft Engine Forum
    Last Post: 03-20-2008, 07:17 AM
  5. Proper timing for 454 Different timing marks
    By rmm in forum Crusader Marine Archive
    Last Post: 08-01-2007, 07:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
