Results 1 to 2 of 2
  1. #1
    Default "Hi, I've removed the
    I've removed the bottom section of the stern drive from my boat to replace the pump impeller. Two re-assemble the stern drive is it necessary to put the boat and bottom stern drive section in fwd gear?
  2. #2
    Join Date
    Jul 2008
    Northboro, Ma, USA
    Default Yes The bronze or stainless
    The bronze or stainless steel shift arm must face 12:00 striaght forward while holding a light force on the prop in a c'clockwise direction
    The splined shaft if you have that model which goes into the bronze arm must be turned clockwise as far as it will go while turning the prop c'clockwise and again holding pressure on the prop to keep it in forward and keep the splines from moving.
    It is a bit of a juggling act to get everything lined up but take your time....
    this keeps it locked in forward gear
    Northborough Ma
    Helping others sometimes with an attitude....haha..
Similar Threads
  1. Raw Water Pump repair question
    By sandkicker in forum Mercruiser Sterndrive Forum
    Last Post: 07-19-2010, 10:30 PM
  2. 1999 90 hp Mercury Water Pump repair kit
    By roadpacker in forum Mercury Mariner Outboard Forum
    Last Post: 03-24-2010, 07:55 AM
  3. Water Pump Repair Kit
    By onlyfinol in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-31-2007, 10:06 AM
  4. Water pump repair 90hp Johnson
    By bobejoe in forum Johnson Evinrude Outboard Archive
    Last Post: 04-12-2004, 10:42 PM
  5. Water pump repair on a 55 Johnson
    By Mike Neels in forum Johnson Evinrude Outboard Archive
    Last Post: 04-24-2003, 08:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
