Results 1 to 4 of 4
  1. #1
    Default "Please see picture. Is this
    "Please see picture. Is this rubber ring supposed to be fitted to the pumps water tube as shown or is this thw "slinger" that should be on the drive shaft just above the sea water pump?
    [IMG]http://img38.imageshack.us/img38/5686/img6638w.jpg"[/IMG]"
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,198
    Default goes on the driveshaft
  3. #3
    Join Date
    Aug 2009
    Location
    Sydney, NSW, Australia
    Posts
    211
    Default goes on the driveshaft. cant s
    goes on the driveshaft. cant sling oil if it aint spinnin.
  4. #4
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    Default It does not sling oil just so
    It does not sling oil just so you know.
    It is a gasket if you will that keeps exhaust from entering the top of the water pump housing and mixing with the cold water.
    I usually put a small amount of grease on the bottom suface so it spins freely on the pump housing.
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
Similar Threads
  1. Upper Drive Shaft Seal in Alpha One
    By McKerracher in forum Mercruiser Sterndrive Forum
    Last Post: 06-10-2010, 01:10 PM
  2. Prop shaft and drive shaft Chrysler 6 hp
    By parker in forum Chrysler Force Outboard Forum
    Last Post: 12-23-2008, 12:06 PM
  3. Replies: 3
    Last Post: 10-13-2008, 07:08 PM
  4. Can you replace a alpha 1 w a Alpha Gen 2 Drive
    By mikem40 in forum Mercruiser Sterndrive Archive
    Last Post: 09-30-2007, 09:41 PM
  5. Alpha Drive Prop Shaft Tolerance
    By cottageboater in forum Mercruiser Sterndrive Archive
    Last Post: 07-14-2006, 11:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
