Results 1 to 7 of 7
  1. #1
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Part # 27-807982 for Mercarb &
    Part # 27-807982 for Mercarb & Rochester 2 BBL base gasket. The gasket is about 1/8" and not 1/4" as previously stated. Gasket greatly improves idle mixture adjustment.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  2. #2
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    902
    Default Could you buy two of them and
    Could you buy two of them and seal them together with a fuel resistant sealant? Maybe overkill?
  3. #3
    Join Date
    Sep 2009
    Location
    Posts
    147
    Default either will work thats you hav
    either will work thats you have adjustments unless you have boiling out the gas if you do then you will need the thicker one two together will work
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "My year old 13" beagle Sa
    "My year old 13" beagle Sadie decided to help me by opening the gasket package. Then she decided it was too big and trimmed it for me; 10 piece gasket now! "
  5. #5
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default "I never keep my boat parts wh
    "I never keep my boat parts where kids or animals can get to them. Problem is, I loose them myself cuz I hide them so well..
    I got a very thick gasket from a Carb Shop, had the right bore and bolt holes, the outside shape was a little off, but there weren't any interferences."
  6. #6
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,643
    Default Re: "10 piece gasket".
    Re: "10 piece gasket".... Isn't that what gasket cement is for? L.O.L.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  7. #7
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    902
    Default "Follow her around long enough
    "Follow her around long enough you'll get them back. [img][/img]"
Similar Threads
  1. Gasket material 006 thick
    By jlash in forum Chris Craft Engine Forum
    Last Post: 11-20-2009, 10:01 PM
  2. QJet Thick Gasket
    By btmline in forum Mercruiser Sterndrive Archive
    Last Post: 07-23-2009, 12:42 AM
  3. 30L carb base gasket
    By mhaleen in forum Mercruiser Sterndrive Archive
    Last Post: 07-17-2009, 10:39 PM
  4. Thick 470 carb base gasket
    By mark_searay in forum Mercruiser Sterndrive Archive
    Last Post: 04-23-2009, 11:32 AM
  5. Crusader 74L Rochester Carb Base Gasket
    By cruisers00 in forum Crusader Marine Archive
    Last Post: 05-10-2008, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
