Results 1 to 3 of 3
Thread: Coupler grease
  1. #1
    Join Date
    Aug 2009
    Location
    camrose, alberta, canada
    Posts
    9
    Default "can the wrong grease cause a
    "can the wrong grease cause a coupler failer, enigne alignment ok, splines on drive shaft ok, u joints new, and greased, gimball bearing ok and greased, splines worn thin and pointy in coupler, any suggestions"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Lack of grease can contribute.
    Lack of grease can contribute. Replace it; need to pull the engine.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,788
    Default "They do not last for ever and
    "They do not last for ever and depending how hard the boat is used, how heavy it is, etc etc etc..
    It is what it is and it wore out....."
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
Similar Threads
  1. What does this nipple grease?
    By 1stboat in forum Volvo Penta Gas Engine Forum
    Last Post: 04-30-2010, 01:17 PM
  2. Grease fittings
    By redsnapper386 in forum Mercruiser Sterndrive Archive
    Last Post: 02-02-2009, 02:02 AM
  3. How much grease
    By glastron in forum Volvo Penta Gas Archive
    Last Post: 08-31-2007, 07:53 PM
  4. OMC Grease
    By 51lyman in forum Johnson Evinrude Outboard Archive
    Last Post: 05-31-2007, 08:54 AM
  5. Grease
    By tom_barker in forum Johnson Evinrude Outboard Archive
    Last Post: 09-17-2006, 09:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
