Results 1 to 4 of 4
  1. #1
    Join Date
    Sep 2009
    Location
    Middle island, New York, United States
    Posts
    2
    Default "About two weeks ago my alarm
    "About two weeks ago my alarm went off and I discovered that the fill bottle for my gear oil was empty. I topped it off and now I'm using about a half pint every 1/2 hour of cruising. No oil in bilge area, and no oil slick when idling. I let engine run at idle for about a half hour a couple of days ago and there was no drop in gear oil or a slick. I seem to be losing it under power only. Any ideas/ suggestions? I want to get another month of boating in before I pull the boat for the winter. Obviously, I'll most likely pull the drive and pressure check then."
  2. #2
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default don't need to pull the dri
    don't need to pull the drive to pressure test it - can do it on the boat.
    9 times out of 10 fishing line has gotten in behind the prop and damaged the propshaft seal.
    Repair of that seal can also be done without pulling the drive.
    As far as making it to next spring- your call on the cost of gear lube and conscience about dumping it in the lake.
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
  3. #3
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,539
    Default "[b]"As far as making it t
    ""As far as making it to next spring- your call on the cost of gear lube and conscience about dumping it in the lake."
    Ayuh,....
    And,... Usually, if Oil is leaking Out,...
    Water is leaking In...."
  4. #4
    Join Date
    Sep 2009
    Location
    Posts
    2
    Default I am not looking to make it un
    I am not looking to make it until next "Spring". I take the boat out in October. I have noticed that the oil level does not drop if under 2000 rpm's. I will most likely get to fish in the harbor once or twice more this season. I certainly do appreciate you feedback. Thank You.
Similar Threads
  1. 2001 bravo 3 recurring oil leak
    By hardwired in forum Mercruiser Sterndrive Forum
    Last Post: 09-08-2011, 11:17 PM
  2. Gear oil leak at bravo one drive
    By hawkmiller in forum Mercruiser Sterndrive Archive
    Last Post: 06-30-2009, 03:08 PM
  3. Bravo drive oil leak in bilge
    By captk in forum Mercruiser Sterndrive Archive
    Last Post: 05-19-2008, 02:45 PM
  4. 71 Bravo 1 intake manifold leak
    By robert soper in forum Mercruiser Sterndrive Archive
    Last Post: 09-05-2006, 02:21 PM
  5. Mercruiser Bravo III drive oil leak
    By aitkens in forum Volvo Penta Gas Archive
    Last Post: 03-06-2006, 05:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
