1999 optimax 200 leaking injection oil out exhaust
leaking pure injection oil out
leaking pure injection oil out the exhaust above cavitation plate & also leaking through prop with engine stored down. sometimes it leaks sometimes it doesnt. but when it does it will be about a 3 inch diameter circle. checked pulse check valve it is fine with no oil in hose.
Are you positive that it's
Are you positive that it's (fresh) oil and not burnt residue that has slimed it's way down the exhaust housing and out the exhaust (thru the prop hub - which would be totally normal)....
