"I suggest that you look aroun
"I suggest that you look around somewhat for a different "mechanic". Things to do yourself that doesn't require rocket science mentality.......
Check spark plugs for traces of water. Check compression. Let us know what you find here.
Describe exactly what the spark plugs look like. What make and type (number) spark plugs are you using,and at what gap?
Spark plugs removed, check spark which should jump a 7/16" gap with a strong blue lightning like flame.... a real SNAP! Does it? No tester? Read on.
(Spark Tester - Home Made)
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
