502 XLi Crusader Engines Port will not idle
rogerledbetter
"Twin 502s, port engine runs b
"Twin 502s, port engine runs bad at low rpms and cuts off when idling, check engine light comes on and off, runs great at wide open -starboard is perfect, I have changed fuel filters, risers, plugs, wires and replace throttle body injector, any ideas what could be wrong?"
Get a scan tool and check the
Get a scan tool and check the codes from the computer. Most likely a sensor is providing out of tolerance values causing the computer to pulse the injectors incorrectly.
