Results 1 to 8 of 8
  1. #1
    Default "I struck a rock today, wasn&#
    "I struck a rock today, wasn't going very fast, no prop damage and seemed to just flatten the skeg out abit on the bottom. The engine stalled though and now it won't even turnover. It's like its stuck in gear or something but the starter can't even turn the motor over? Any suggestions could I just jammed the gears in the lower end or am I in serious trouble?"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "What year, engine, OD? Won&#
    "What year, engine, OD? Won't turn over meaning the engine won't crank or it cranks but won't start?"
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Default 89 3.0 l with alpha 1 outdrive
    It has plenty of amps to turn over but the engine won't even crank. the starter engages but won't turn the engine over.
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Pull the spark plugs out and s
    Pull the spark plugs out and see if it's hydrolocked. If it is not then take off the OD and see if it will crank the engine.
  5. #5
    Default Not to sound ignorant but what
    Not to sound ignorant but what do you mean by hydrolocked?
  6. #6
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default "hydrolocked is when water get
    "hydrolocked is when water gets in the cylinders, common problem with bad Intake/Exhaust manifolds and risers on that engine. Can also be from a cracked cylinder head or blown head gasket, and rarely cracks in the cylinders themselves."
  7. #7
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,788
    Default ROCK = OUTDRIVE = possible loc
    ROCK = OUTDRIVE = possible lock up/broken gear.......As Guy suggested.
    Remove the outdrive and retry starting engine.
    If it starts the problem is in the outdrive.
    If so let us know and/or have marina look at it.
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
  8. #8
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    902
    Default "Hydrolock is when water gets
    "Hydrolock is when water gets in the cylinders and doesn't compress like fuel/air mix does. It can bend connecting rods and other internal crucial items. Even if no damage, if the water is not addressed quickly it can rust your rings to the cylinder walls.
    No prop damage? I'm leaning towards hydrolocked but hopefully I'm wrong. If water shot past your shutter (if it is in bad shape or missing) when you stopped suddenly you could shot water into the engine while running and caused some havoc. Like I said, hopefully wrong."
Similar Threads
  1. 2002 DF 115 hp wonbt turn over
    By garthboyd in forum Suzuki Outboard Forum
    Last Post: 01-01-2010, 04:58 PM
  2. Wonbt turn over
    By labman in forum Mercruiser Sterndrive Archive
    Last Post: 08-20-2009, 07:55 PM
  3. BF 50 wonbt turn off
    By antoic in forum Honda Outboard Archive
    Last Post: 08-18-2008, 10:02 PM
  4. 120 Hp VR0 wonbt turn
    By m_c_chase in forum Johnson Evinrude Outboard Archive
    Last Post: 08-04-2008, 01:44 PM
  5. Hit rock bent prop a little now wonbt go into gear
    By harold in forum Mercruiser Sterndrive Archive
    Last Post: 08-30-2006, 08:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
