Results 1 to 11 of 11
  1. #1
    Default "Hi, How do I remove the
    "Hi,
    How do I remove the copper thermostat sleeve on a 4.3 L mercruiser without destroying it? Just trying to change my thermostat. The engine is sea water cooled.
    Thanks!"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Danny: You can try some CLR
    Danny:
    You can try some CLR around the edge; it's rusted in place along w/the thermostat. I just pry it out along w/the t'stat.
    Clean out the rust and scale for the sleeve and t'start base using a Dremel and coarse sanding drum then finish polishing the sleeve and seat area w/a finer drum. Best tool you will ever buy.
    You can also soak the disassembled t'stat hsg. for 3 hours in a bucket of muriatic acid (DANGEROUS BURN HAZARD) to clean out the internal passages. Remove any plugs and the ball valve "T" assy. first. Rinse well and blow dry. Use the dremel as needed.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Default What about heat from a propane
    What about heat from a propane torch?
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default The sleeve is too thin and wil
    The sleeve is too thin and will expand w/the heat. You could apply ice to the sleeve after the heat; it may come out.
  5. #5
    Default Thats what I was thinking that
    Thats what I was thinking that the expansion and cotraction would break it free?
  6. #6
    Join Date
    Feb 2008
    Location
    Lake Norman, NC
    Posts
    227
    Default "Clean the entire unit by soak
    "Clean the entire unit by soaking in radiator cleaner (oxalic acid power in water). After soaking a few hours, dry off a little bit and liberally use penetrating oil around the sleeve edges, top and bottom. Sometimes this alone allows you to slowly tap the thermostat out along with the sleeve.
    If you have not yet gotten it out, drive the thermostat out with a block of wood (destroys the thermostat of course). This leaves a very thin gap above the sleeve. If you are lucky you may have a small puller that will engage the upper rim of the sleeve in the gap. If not, use a screwdriver blade and use many light taps with a mallet around and around the edge of the sleeve driving it out slowly. Sometimes you get lucky and can press it out using the "windows" in the sleeve. Just work slowly to not damage the housing.
    If the sleeve is reluctant to go back in the housing, liquid soap is a good lubricant with a flat block of wood as a tapping surface."
  7. #7
    Default So far I have the thermostat o
    So far I have the thermostat out. I was destroyed as you said but the sleeve remains in place. I've left it soaking in penetrating oil.
  8. #8
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Use PB Blaster; it eats the ru
    Use PB Blaster; it eats the rust.
  9. #9
    Default "Funny, I bought some PB bl
    "Funny,
    I bought some PB blaster today because I was out of WD-40. First time I senn PB, is it any good?"
  10. #10
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default I've been using it for yea
    I've been using it for years on rusted nuts and bolts.
  11. #11
    Default PB worked like a charm. After
    PB worked like a charm. After a few hours tapped it out with a hammer and screw driver.
    Thanks!
Similar Threads
  1. OMC 2.5 liter engine removal
    By Dan_mcfly in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-04-2011, 11:04 AM
  2. 1983 70hp thermostat removal
    By scortyduck in forum Mercury Mariner Outboard Forum
    Last Post: 08-07-2010, 04:31 PM
  3. Engine sleeve removal 200 hp Merc
    By hattrick1068 in forum Mercury Mariner Outboard Forum
    Last Post: 12-07-2009, 05:13 AM
  4. Thermostat testing and removal
    By piperdog in forum Johnson Evinrude Outboard Archive
    Last Post: 11-11-2009, 03:22 AM
  5. Thermostat for 38 Liter OMC 800
    By gtcarolina in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-28-2006, 11:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
