Results 1 to 4 of 4
  1. #1
    Default "My stern drive will not go in
    "My stern drive will not go into reverse. I disconnected the cable on the engine and tried to adjust it according to the book. The cable is not binding, and by pushing it in it goes into forward fine. When I pull the cable out, it will not go into reverse. Any ideas"
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,244
    Default "Pull the drive and check it m
    "Pull the drive and check it manually.Sometimes some mud gets packed in the slide and it wont allow enough travel inward for reverse.plastic roller on the shift arm broken, shift spool on lower unit worn."
  3. #3
    Default Thanks for the info. I will d
    Thanks for the info. I will do that this weekend and see if that fixes it. I also ordered a new shift shaft bushing. Might as well change it when I have it down
  4. #4
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,799
    Default Also look close at the gimbal
    Also look close at the gimbal housing where the stainless steel shift link with the upside down U shape meets the bronze shift link sticking out of the lower unit. The fit between them should be rather tight. If there is too much slop you will loose reverse.
    Also look to see if the bronze piece is worn or bent and look closely at the stainless steel upside down U and make sure it is straight NOT BENT.
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
Similar Threads
  1. 96 alpha one shift cable tool
    By sgtsaks39 in forum Mercruiser Sterndrive Forum
    Last Post: 06-08-2010, 07:33 AM
  2. Shift cable adjustments on alpha 1 mr
    By skip1555 in forum Mercruiser Sterndrive Archive
    Last Post: 05-24-2009, 01:16 PM
  3. Alpha Shift Cable Leak
    By captngoderich in forum Mercruiser Sterndrive Archive
    Last Post: 05-16-2009, 01:44 PM
  4. Shift cable on Alpha drive
    By gaffney1951 in forum Mercruiser Sterndrive Archive
    Last Post: 04-13-2009, 09:41 PM
  5. Alpha 1 shift cable
    By jerryh in forum Mercruiser Sterndrive Archive
    Last Post: 09-20-2007, 06:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
