Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2006
    Location
    Winchester UK
    Posts
    205
    Default My 1991 350 magnum runs well b
    My 1991 350 magnum runs well but needs a tweek on the mixture screw as it does not run as smooth as it could. It does not misfire though. Is there a special tool for adjusting the carb as I can see the adjusters but getting to them seems impossible. Is it a flexible shaft adjuster?
  2. #2
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default "yes, and best done in the wat
    "yes, and best done in the water, warmed up, and in gear"
  3. #3
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,802
    Default "Here is a link to sears where
    "Here is a link to sears where you can buy the correct tool.
    It is also the one I have, it comes with 5 tip ends for different configurations.
    I am assuming it is a rochester 4bbl.
    http://www.sears.com/shc/s/p_10153_1...070921x00003 d"
    Jack
    Northborough Ma
    Helping others sometimes with an attitude....haha..
  4. #4
    Join Date
    Apr 2006
    Location
    Winchester UK
    Posts
    205
    Default Thats exellent. Thanks very mu
    Thats exellent. Thanks very much for the info.
  5. #5
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default I just slip a 1/4" drive s
    I just slip a 1/4" drive socket over the screw which gives me something to grab w/my fingers. I have a 2 BBL Mercarb w/1 screw behind the T'stat hsg.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  6. #6
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,802
    Default "The Rochetser 4BBL has two un
    "The Rochetser 4BBL has two unique a/f screws that are difficult to get to, to say the least.
    Most especially the older motors it was near impossible to reach with my tool never mind a 1/4 drive socket.
    Jack
    Northborough Ma
  7. #7
    Join Date
    Apr 2006
    Location
    Winchester UK
    Posts
    205
    Default Thats exactly what mine looks
    Thats exactly what mine looks like. Thanks. I will get the tool ordered and get someone to pick it up for me.
Similar Threads
  1. adjusting carb while useing 56 evinrude 7.5
    By irishwoodsman in forum Johnson Evinrude Outboard Forum
    Last Post: 05-04-2010, 02:19 AM
  2. How to adjust RPMbs while adjusting the ss mixture screw
    By kmwracer in forum Johnson Evinrude Outboard Archive
    Last Post: 07-02-2009, 04:17 PM
  3. Adjusting the carb and distributor
    By whydell in forum Volvo Penta Gas Archive
    Last Post: 06-17-2009, 09:18 AM
  4. Carb mixture adjustment
    By terrible_t in forum Mercruiser Sterndrive Archive
    Last Post: 04-24-2009, 07:30 PM
  5. Sea king 12 Hp carb mixture questions
    By jjimmy in forum Archive 2003-2009
    Last Post: 04-23-2008, 09:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
