Results 1 to 3 of 3
  1. #1
    Default is it possible to replace the
    is it possible to replace the two prop shaft seals without removing the carrier bearing?
  2. #2
    Default I can't say it is not poss
    I can't say it is not possible but why risk damage to the expensive shaft or carrier seal surface. It is easy to remove the carrier but you must have the proper tools.
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,158
    Default "possible, Yes. another ca
    "possible, Yes.
    another case of needing the proper tools."
Similar Threads
  1. prop shaft seals 92 120hp
    By macktack in forum Johnson Evinrude Outboard Forum
    Last Post: 08-21-2010, 07:01 AM
  2. Replacing Lower unit prop shaft oil seals Honda BF50A 50hp
    By opiebf50a in forum Honda Outboard Archive
    Last Post: 12-08-2008, 12:13 AM
  3. Prop shaft seals
    By merlin in forum Honda Outboard Archive
    Last Post: 09-14-2008, 07:10 PM
  4. Replacing DPS prop shaft seals
    By getaway in forum Volvo Penta Gas Archive
    Last Post: 04-29-2007, 07:07 PM
  5. Prop shaft seals leaking
    By taffyfester in forum Volvo Penta Gas Archive
    Last Post: 07-04-2006, 03:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
