Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2008
    Location
    Lakewood, NY USA
    Posts
    317
    Default "On a 1979 Mercruiser 165 I-6
    "On a 1979 Mercruiser 165 I-6 engine, what should the timing degree be at idle and advance at WOT"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "6 deg. initial, max deg., not
    "6 deg. initial, max deg., not sure"
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,086
    Default "Full advance is 27 deg, +
    "Full advance is 27 deg, +/- 2 deg, all in by 2800 RPM, according to the manual."
  4. #4
    Join Date
    Oct 2008
    Location
    Lakewood, NY USA
    Posts
    317
    Default Thank You makomark!! Thank You
    Thank You makomark!! Thank You very Much
  5. #5
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,086
    Default You're Welcome.
    You're Welcome.
Similar Threads
  1. Timing specs
    By big_tentacles in forum Mercruiser Sterndrive Archive
    Last Post: 07-23-2009, 07:55 PM
  2. Adapt an outdrive from a 43lx to a straight 6 merc 165
    By currenjw in forum Mercruiser Sterndrive Archive
    Last Post: 06-29-2009, 04:02 PM
  3. 1986 30 OMC Timing Specs
    By 2thepoint in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-05-2008, 02:42 PM
  4. Timing specs
    By dnspiveral in forum Johnson Evinrude Outboard Archive
    Last Post: 03-20-2008, 06:21 AM
  5. Timing specs
    By gps in forum Mercruiser Sterndrive Archive
    Last Post: 06-08-2007, 10:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
