Results 1 to 8 of 8
    Sep 2009
    philadelphia, PA,
    3
    Default My 4.3L MPI engine won't s
    My 4.3L MPI engine won't start when it's cold but once it warms up it runs fine. When it won't turn over I smell a gas. It sounds like it isn't getting enough air. Last weekend I put a small space heater in the engine compartment for a little while to bring up the temp of the engine and it stared easier still not normal but easier.
    Aug 2006
    SW Ohio, USA
    10,396
    Default Clean the flame arrestor on th
    Clean the flame arrestor on the throttle body. Use brake cleaner sprayed from the inside out or spray heavily w/a degreaser and rinse from the inside out w/hot water. Blow dry w/compressed air. What do the spark plugs look like? Original plugs? Time for a change if they are not platinum; just clean them.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
    Sep 2009
    philadelphia, PA,
    3
    Default I did notice some black build
    I did notice some black build up on the trottle body butterfly valve. The flame arrestor has no filter element I thought this was strange. The flame arrestor is just a covering with hole almost like a sink stainer. I can see right thru it. Is that right? I haven't changed the plugs since i got the boat so I will change them.
    Aug 2006
    SW Ohio, USA
    10,396
    Default Flame arrestor usually has a m
    Flame arrestor usually has a multilayer coarse screen about 1.5" high around the cover. The dirt you saw on the butterfly (BFV) valve is critical. Get a can of THROTTLE BODY (TB) cleaner and not carb cleaner. Hold the throttle open and liberally spray both sides of it and the bore of the TB. Wipe it clean w/white paper towels. Spray the shaft ends of the BFV and then lube the shaft ends w/a drop of light oil. Lube all the linkage pivot points on the TB you'll be surprized how much smoother the idle will be.
    Aug 2006
    SW Ohio, USA
    10,396
    Default I would also dump a can of Sea
    I would also dump a can of SeaFoam into the fuel tank; 1 can for each 10 gallons of gas for now and run the tank down to 1/4. Then add 1 can of SeaFoam to each tank fill up for PM. You'll never have a varnish/gum issue again.
  6. #6
    Sep 2009
    philadelphia, PA,
    3
    Default Thanks for the info. My flame
    Thanks for the info. My flame arrestor is only single layer coarse. Also what type of filter material do I stuff in those side orifices in the throttle body??
  7. #7
    Jul 2008
    , sc,
    104
    Default The "flame arrestor" d
    The "flame arrestor" does not contain any filtering material. It's there only to prevent flame from coming out the air intake in case of backfiring. Prevents the boat from exploding gas fumes. There is no air filter on gas marine engines like you have on a car. The flame arrestor over time can collect enough oil vapor and stuff to start to suffocate the engine - that's the reason to keep it clean.
  8. #8
    Sep 2008
    Maryland - USA
    7,184
    Default "If it wont start on its own a
    "If it wont start on its own and you smell fuel, one of the sensors providing info to the ECU is going bad. Best to get a scanner tool and find out which sensor (or its connections) is out and fix it. Its probably riching up the whole fuel curve which is costing you a fair mount of fuel."
  1. 2003 50 TLRB wwill not start cold
    By franc in forum Yamaha Outboard Forum
    Last Post: 09-23-2010, 04:18 PM
  2. Mercruiser engine turns over but wonbt start
    By jackman in forum Mercruiser Sterndrive Archive
    Last Post: 06-13-2009, 10:09 PM
  3. Cold engine wonbt start
    By elroy in forum Johnson Evinrude Outboard Archive
    Last Post: 04-01-2008, 08:18 PM
  4. 2003 Mercury 90hp 2stroke hard to start cold
    By mangofish in forum Mercury Mariner Outboard Archive
    Last Post: 06-20-2007, 08:40 PM
  5. Cold start up of 2003 DT 150
    By poorfarm in forum Suzuki Outboard Archive
    Last Post: 03-01-2006, 07:17 AM
