Winterize
Carry out the full recommended
Carry out the full recommended service schedule detailed in the owners manual. Ensure the cooling system is throughly flushed if it has been used in salt water
Be sure to drain and refill the gear case. You dont want any water in there to freeze. Anyway during the winter is the time to replace seals etc not when you are wanting to use it again. Also check/change the pump impeller.
Fog the power head.
Drain the fuel remaining in the carb.
Be sure all water is drained from the leg and store it upright.
