Results 1 to 3 of 3
  1. #1
    Join Date
    Aug 2007
    Location
    Toronto, Ontario, Canada
    Posts
    4
    Default Twice now I have had the situr
    Twice now I have had the situration when my 90 HP 1991 envinrude would not turn over until I moved the remote lever back and forward a couple of times.
    I'm worried about getting stuck somewhere and would like to correct this issue.
    Can anyone tell me how to check the neutral safety switch?
    Are they hard to replace?
    I have the Seloc manual and its not much help for this particular issue.
    Thanks in advance for your help.
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    13,525
    Default "If you have the normal (u
    "If you have the normal (usually white) side mounted control box, it's simply a matter of splitting the box and adjusting the switch slightly closer to the cam that actuates it.
    If a console mount, look under the mount, study where that small switch is..... the adjustment should be obvious."
    Our questions require answers. If you refuse to answer our questions, how can we answer yours?
  3. #3
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "Or a case of cable wear, bush
    "Or a case of cable wear, bushing wear in the box.
    Anyway, no big deal, no big costs."
Similar Threads
  1. Neutral safety switch versus shift kill switch?
    By Pal in forum Mercruiser Sterndrive Forum
    Last Post: 10-26-2010, 02:32 AM
  2. Neutral safety switch
    By redsnapper386 in forum Mercruiser Sterndrive Forum
    Last Post: 09-28-2009, 06:50 PM
  3. Neutral safety switch
    By crag47 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-20-2008, 04:53 PM
  4. Neutral safety switch
    By rich_b in forum Mercruiser Sterndrive Archive
    Last Post: 09-27-2007, 05:10 AM
  5. Starter or Neutral Safety switch
    By jsimon in forum Mercruiser Sterndrive Archive
    Last Post: 12-15-2006, 06:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
