"I have a 1979 22' SeaRay
"I have a 1979 22' SeaRay with a Chevrolet 305. The engine has about 200 hours on it since a rebuild. The boat has been idle for the past five years so I drained all the old fuel, flushed the tank, had the quadrajet rebuilt, replaced all filters, replaced fuel pump, changed plugs, points, condensor, rotor and dist cap. Timing is set to 8 deg. btdc. It will start and run with no problem but after about ten minutes, it will just die at anything above 1000 rpms. After a cool down break of about 10-15 minutes, it will run fine again for about 10 minutes then I cannot throttle up at all, it will only idle up to 700-1000 RPMs."
